formula needed help
searley
Sep 12, 2008
320
can any one show me how to get the formula for this ?
the reactance of a 1uF capacitor connected across a 50HZ supply is ?
the answer is 3.18kohms i can`t work out how to use the 1uF and what it stands for.
while you are here can you check this out
an electric heater dissipates a power of 3.0KW when connected to 230v a.c supply is ?
i get 13.04 doing it 3000/230 but on the answer sheet it says the answer is 17.7ohms ? how is right
3000/230 gives you the current
you need V=IR, rearrange R=V/I
230/13 = 17.64ohms
Dont know your answer to your first one but i'm sure someone will.
As for the second you have worked out the ampage, however going by the answer they have the are looking for the reisistance. You are half way here,
To get this you would need 230/13.04 which gives 17.64ohms.
Hope i'm right. ?:|
Dont know your answer to your first one but i'm sure someone will.As for the second you have worked out the ampage, however going by the answer they have the are looking for the reisistance. You are half way here,
Hope i'm right. ?:|
I concur macca ;)
The mind still works even after these.
Guiness DrinkGuiness DrinkGuiness DrinkGuiness DrinkGuiness DrinkGuiness Drink
Xc = 1/ 2PIfc
Xc = capacitor reactance
2pi = two pie (because I dont have the pi sybol)
f = frequency
c = capacitance in farrads (in your case it micro farads thats 10 to the -6)
Any help ?
see attachment
can any one show me how to get the formula for this ?the reactance of a 1uF capacitor connected across a 50HZ supply is ?
img024.pdf
  • img024.pdf
    14.6 KB
Removed my post because the formula didn't come out right and editing it didnt rectify it so I'll try another way, thanks for pointing out my mistake andy.
Capacitive reactance (Xc) is the opposition to an a.c current in a capacitive circuit. It causes the current in the circuit to lead ahead of the voltage
Xc=
1/
2nfC (ohms)
1/ = 1 over
Xc= capacitive reactance
n= pi
f= Frequency (Hz)
c= capacitance (f)
so,
2xnx50x1 = 314.159
1/314.159 = 3.183ohm
Pi formulae now added to the "Smiley" section.
pi
:D
I have set it up to automatically replace the p & i when used together.
