Theorysparky
Domestic Electrician
- Feb 18, 2008
- 4,232
- 0
you started it !!!!! :^Oand sorry apache - all you wanted was some help with a electrical problem and everyone has hi-jacked the thread with headlight posts!
i simply mentioned that he should get a decent head torch!you started it !!!!! :^O
(mine is the one with 5 LEDs too - was a little lazy with my link to be fair!)apache - i was thinking of a seperate battery pack... but then i thought if needed, i could mod mine to take an external battery and just have an empty box on the head strapAlso, what do you think of the brightness of the 14 led's? mine only has 5 but is bright enough for just about everything i do
the more I think about it the more I think this is what's happened. Andy worrying me there!I`m with Theo on this one mate - sounds like a switch line. Lets play hunt the neutral.![]()
Great game when you cut into a t+e to add to a circuit, and find its actually switch wire. Arrrrgh. Can`t we all use twin brown / red??
mines normally only used for 2-3 hours max, and i keep spare batteries in van which is never far away, so dont have much of a problem with it having less capacity.(mine is the one with 5 LEDs too - was a little lazy with my link to be fair!)I needed a halogen bulb too as blood looks black under LED's and that's no good for surgery
I usually use it on the LEDS. I tried the one you have and mine in a camping shop and like the fact that there's no weight on my neck. The batteries last ages, 4 C cells have a much higher capacity than AA's.
I am a self confessed torch snoband sorry apache - all you wanted was some help with a electrical problem and everyone has hi-jacked the thread with headlight posts!
me neither. I tried it in a camping shop and bought it formines normally only used for 2-3 hours max, and i keep spare batteries in van which is never far away, so dont have much of a problem with it having less capacity.i didnt get mine from a local shop, so didnt get the chance to try them on or anything
i wasnt trying to worry you! (OK, maybe i was a little bit!)the more I think about it the more I think this is what's happened. Andy worrying me there!Think a spur off the upstairs radial is my best bet! can even use the FCU as the switch. No rooting under insulation and college notes either!
I'll never get a horse through my loft hatch. Will have to do it the old fashioned way with cable and batten lampholdersi wasnt trying to worry you! (OK, maybe i was a little bit!)and why do you need college notes to install SFCU?
so connect the output of the cows heart to the live at SFCU. maybe earth via cows brain. at the light, install a dogs ear between live and neutral for surge protection. neutral can be taken to any horse you can find.
NOYou buy your power tools from a camping shop???
Right O patch me old skiny wig lover!BlushingI want a light in my loft. I'm even allowed to fit one, now i have 2 JB's accessable both with a single wire going in and out (used to extend a circuit?).My volt detector detects them as live. Remove the cover amd my fluke T50 illuminated at 230V (only 1 light) when red probe on either L or N.
When testing between L&N I get nothing but L&E or N&E give me 230V (all lights lit)
What's happeneing here? How can I have a reading with only 1 probe?
1 CABLE! i.e. T&E is a cable with three conductorsGood tiperm there are two seperate JB's each only has 1 wire in 1 wire out. (each wire is old colour T&E)
I will try to trace the wires back. All the lights upstairs are 2 way - wired with a pull cord over the beds. To add confusion.1 CABLE! i.e. T&E is a cable with three conductors1 wire is a single
i.e. 1 neutral or 1 earth or 1 live!
did you get the same readings at BOTH jb's
cant you trace the wires back to a light fitting?
you will get a proper neutral at a light fitting!![]()
You have got to run up the wall to get into the loft void! :_|I will try to trace the wires back. All the lights upstairs are 2 way - wired with a pull cord over the beds. To add confusion. loadsa 2 ways!! 99.9% that is waht you are testing across then!
I can trace back yes. Might have to take a few wires out of some switches and check continuity? I hate 2 way lighting.
Seriously tho - is there any advantage of tapping into the lighting circuit for a 60W bulb over using the upstairs radial with a suitable 3A Sw spur?
It's easier - I can ID the 2.5mm cable!
There has - it's just finding it. I have more light switched upstairs than double sockets!You have got to run up the wall to get into the loft void! :_| No I use a ladder! You mean to spur from radial? It loops into the loft down into a stud wall. So I have easy access to it. Funny wiring in me very old house.
There has GOT to be a perm live and perm neutral already in the loft for the u/s lights![]()
