use a neon screwdriver Deke
"Deathtraps-r-us". Neon drivers should be banned / outlawed / hung
Or even all 3.
IMOGuiness Drink
maybe the people who use them should get the same punishment:O:O"Deathtraps-r-us". Neon drivers should be banned / outlawed / hung
Or even all 3.
IMOGuiness Drink
Have decided to use the radial. Will be easier.Patch I think it may be easier for you if you use that radial you mentioned. Switched spur , 3 amp fuse, nice and easy. The other way you could be connecting to the strappers or a live and switch wire etc. You just need to verify that polarity is correct on your lighting, use a neon screwdriver at the switches ( in the on position in case its switching the neutral)Deke
I have a non-contact volt alert, a multimeter and a T50 voltage testing thingy. Don't fancy been the path to earth. Think I can test for current without a neon screwdriver:O:O"Deathtraps-r-us". Neon drivers should be banned / outlawed / hung
Or even all 3.
IMOGuiness Drink
INDEED! I didn't realise your sockets came though the roof & down walls!Have decided to use the radial. Will be easier.![]()
I have a non-contact volt alert' date=' a multimeter and a T50 voltage testing thingy. Don't fancy been the path to earth. Think I can test for current without a neon screwdriver
Thanks for help on this thread guys.[/quote']
yes they do.INDEED! I didn't realise your sockets came though the roof & down walls!
No & NoAh but did you check the polarity, Patch ? And did you use a ( dare I say it) neon ??Deke
should i bring my own rope.........maybe the people who use them should get the same punishmentGS38 etc all says leads should be double insulated, fused etc etc....
....then you get a neon screwdriver which uses your body as part of the test circuit. which bright spark came up with that!
we missed youshould i bring my own rope.........when someone comes up with a simpler,easier faster way to find a broken N without an E reference then I'll be glad to reconsider my NEON, until then it will remain my constant companion,
get a fluke T series. even the vet has one. they dont need anything to reference with for tell you if its liveshould i bring my own rope.........when someone comes up with a simpler,easier faster way to find a broken N without an E reference then I'll be glad to reconsider my NEON, until then it will remain my constant companion,
My feelings exactly, thanks Steps . Guiness Drinkshould i bring my own rope.........when someone comes up with a simpler,easier faster way to find a broken N without an E reference then I'll be glad to reconsider my NEON, until then it will remain my constant companion,
please explain, link or summink.get a fluke T series. even the vet has one. they dont need anything to reference with for tell you if its live
one of these:please explain, link or summink.any fancy things i have seen like that either show on any kind of voltage whatsoever, (including induced) or are just too unreliable.
thanks apache.
its just sometimes the old ways are the best, eh Deke? old and simple,,,, like us.
well me anyway.......
my redoh yes, got one, good for ph rotation(I only have a fluke 1652), pure sh17 for anything else. as for proving its still working, all you are doing is testing the battery, you cant prove its working without a known voltage source, as with ANY kind of voltage detector.maybe, but at least shorting the leads will give a continuity reading, so you know that the leads/probes are OK
and it DOES detect induced current.never had a problem with this
and it DOES need a referenced E point.to give a true voltage reading, yes. but it doesnt need anything else to tell you something is live
my NEON?????? well all it needs is a clip for my inside pocket(where it lives each and every day) and one of my thumbsid rather my body wasnt part of the test path... just imaging if that resistor was to fail....![]()
First proper post and controversial from the start.Originally Posted by steptoe
my red
ooh - good pointFirst proper post and controversial from the start.![]()
99% or resistors fail open-circuit, not short-circuit, so risk is quite low?
