probably, but there is still a chance. normal resistor failing may normally be OC, but other things may come into it. like if it gets damp. or if something inside works loose and somehow manages to bypass resistor. very low chance, but could still happenFirst proper post and controversial from the start.![]()
99% or resistors fail open-circuit, not short-circuit, so risk is quite low?
But either way, using your body as part of a test circuit, where if something does go wrong could kill you, doesnt have much appeal to it. so ill stick with my T140
