bluetobits
- Joined
- May 10, 2010
- Messages
- 294
- Reaction score
- 6
Glad it's not just me, I read r.b's posts twice and still can't make head nor tail of them. I'd have more luck reading a Chinese takeaway menu......in Chinese!
RIght andy i test houses with no garage supplys what so ever all i have to know is whats a main protective bond a supplementary bond and thats it a dont know is my answer an earth equipotential bond ?or can it be worded main equipotential bond 10mm ?
You got some beer in your eyes lately, you're forever rubbing them! :innocent:shakehead
No, I mean a Ze,
I did say that it was to help the folks that didn't understand Ra,
You can't measure Ra with a normal Ze loop tester,
A lot of folks on here may not have a tester capable of doing an Ra test.
THere is no gas pipe in the garage or water pipes so no need for a 10 mm earth a get you the armour is fine as an earth all thats in there is socket and switched spur for lights got there finnally yes the 4mm is fine for the supply but on the other hand if there is gas meters water stop taps yes its no good having a 4mm earth to the board or an armour then having a ten mm out to meters and stop taps.then a seperate earth would be required with the armour at least 10mm may b 16mm
