Hello, this is my first time on this forum, so I am hoping you geniuses? out there can assist me.
My problem is that when I run my diesel-generator ( 6kw 230v 50hz 1ph ) to charge my battery bank on board my narrow boat (12vdc) via an inverter-charger, the inverter (Heart Freedom 2000 ) will not stay "locked" on to the generators output, but keeps on tripping out. The only way I can make the inverter stay online is to simultaneously run a 1kw fan heater. this appears to lock down either the generator or the inverter I'm not sure which, whatever, it is a daft state of affairs especially in the summer months when additional heat is not really needed!.
Therefore, can anyone offer a solution to this problem.
Cheers
Cheers
