works for me. no basic protection to be pedanticsteps, that is direct contact is it not?
well I done the drawinghow do you reckon to that?once you use a genny as a supply then your whole installation must now comply with 17th as you have changed the whole installation, so RCDs would be required anyway.
as for how we have two earths,
you have the artificial earth provided by star point(genny or otherwise) and the actual mass of earth that we stand on and that is what conducts the fault current, hence the necessity to rod all supplies,
and once the fault flows through you under fault conditions to actual earth then ALL installations become TT.
do I need to do a drawing?
person connected to filament bulb on the neutral side but were no neutral existsYour drawing is better than mine & I can't see the detail at the point of human contact sorry, my eyes are not brilliant nor is my laptop screen!
if you was at the generator site steptoe mr B could insert his rod in the hole your in and get a great reading:^O
ok, so I missed out the protective device, the drawing was meant to show how the fault travels, without the rod at the star point then the current would not be large enough quick enough to blow the protective device anyway(probably), just enough to kill.works for me. no basic protection to be pedantic the very reason rcd where invented perhaps ? :_|
without the rod at the star point no fault exist and no current would flowok, so I missed out the protective device, the drawing was meant to show how the fault travels, without the rod at the star point then the current would not be large enough quick enough to blow the protective device anyway(probably), just enough to kill.
your drawing isnt very clear - exactly what is the person supposed to have touched? looks like the neutral from the lamp? if it is, then regardless of it being TNS or TT, he's getting a shock.as the person hasnt actually touched an extraneous part that has become live under fault conditions then please explain how else the current returns to star.thanks.
its a very basic drawing to show a person in direct contact with a LIVE part, and NOT in contact with the metal casing(which is earthed,person connected to filament bulb on the neutral side but were no neutral exists
yes it would, the current would flow to generall mass of earth,without the rod at the star point no fault exist and no current would flow
none of you could understand what I was trying to explain so demanded a drawing,thats a bit harsh . the drawing is bad from how it looks i described it:innocent
I believe this is a general term and is not meant or directed at anyone.I thought you may have grasped the basics more than this, maybe I need to do a coloured drawing and include everything
if i need a key to understand it it suggests i'm an idiotSteptoe saidI thought you may have grasped the basics more than this, maybe I need to do a coloured drawing and include everything including an idiots key to what is what
Debate will always be two sided otherwise there is no need for debate. Express your arguments so all can learn from the discussion.
there is NO such thing as no circuit.hang on you said if the star point wasn't earthed . so if it wasn't there is no circuitno circuit is zero current and zero shock
you think about yourself how you wish.if i need a key to understand it it suggests i'm an idiotpeace
