Hi
i am installing a sonos wireless speaker to my bathroom. I found the junction box with the lighting circuit located behind the access panel on the ceiling and I am thinking of hardwiring the speaker using an 3amp fused switch . http://www.screwfix.com/p/mk-13a-dp-switched-fused-connection-unit-with-flex-outlet-white/13479
The speaker is rated at 1amp, it has humity proofing and will be installed in
Alternatively, I could install a secondary socket from a nearby wall socket. But this is more labour intensive and will require tracing 2mtrs of cable through the wall.
Do you see any problems connecting it to the lightning circuit?
