OK, thanks. It was still a great bargain package i got, its just i would have waited an extra month for the HD tuners but got pressurised into getting that one then. This tv has so many gadgets i have not even looked up yet, such as the internet connection.the sky comment wasn't aimed at you mateFULL HD = a resolution of 1920x1080 pixels and capable of displaying a 1080p signal which is a resolution of 1920x1080 in progressive scan.
HD ready = a resolution that is higher than SD(standard definition) but not 1080p("HD" generally has a few recognised resolutions being 480i, 480p, 720i, 720p, 1080i and 1080p but some TV's display a non-standard resolution that has to be scaled sadly. its a bit of a mine field if your not savvy to be honest.)
interlaced = this is how TV used to be displayed, what happened was you had a refresh rate of 50hz (50 frames a second) but it was made up of only 25 images where they displayed the odd lines of a frame followed by the even lines of a frame so it spread a 25fps video over 50fps which resulted in a smoother video but fine horizontal lines would shake/jump if they were split over odd and even lines.
progressive scan = with progressive scan the entire frame would be displayed on every scan so images no longer shake/jump.
i hope that helps rather than hinders.
What about 3d Tv's ?
