sellers
- Feb 2, 2009
- 2,583
- -2
I'm after some ideas on electric heating options, suitable for heating a 10m square room, with no external walls. Storage heaters aren't an option, need something permanent with enough power to heat the room comfortably.
I was thinking along the lines of a 1.5kw panel heater with intergrated timer. Do you guys have any other ideas. Also with 4 x 1.5kw heaters going into a flat would it be suitable to wire as its own 32amp ring. As a lot of installations with heaters I've seen use a 16amp mcb per heater.
