- Nov 28, 2009
- 14,729
- 903
I need a second cylinder thermostat for a job I'm working on.
It's the kind with a capillary tube that feeds into a thermostat pocket on the tank.
But, here's the problem.
The 'stat that came with the tank is that sort, but the main thermostat pocket has a flange on it's end, and the body of the stat clamps onto that flange.
But on this cylinder, the secondary stat pocket does NOT have a flange. It's just a bit of (approx) 10mm copper tube.
So if I had an identical stat, it's body would just hang off the capillary tube and it wouldn't last long.
So I either need a stat where the body has a clamp that will clamp down onto a bit of 10mm copper pipe, OR I need a stat where the capillary is quite long, and the thermostat body can be screwed to the wall about 30cm away.
Any ideas?
---------- Post Auto-Merged at 19:32 ---------- Previous post was made at 19:09 ----------
Something like this one would do Capillary Thermostat BANICO TCS-1 zero to 90degC 19410 | eBay
But my customer really wants to buy it from a "proper" shop so he has a VAT receipt.
Any ideas?
