- Oct 22, 2010
- 14,580
- 1,142
BUT the supply to the B Bar remains?
So fault is after B Bar?
I am not going to use the correct terms as it takes too fricking long. But, I would firstly disconnect each end of the subs and meg them end to end at 1000v to see if something is breaking down, as just doing an Ins Test wont really tell you much in this case.
Pesonally I still thing it is a faecal connection.................... :coat
Just thought, when this happens do you still have a neutral at the B Bar chamber?? or do you just think you have as you are recording voltage between phase/line current
