Use a B6 MCB again but I very much doubt its that. If you are doing Electrical work, why do you not have the correct test kit? If it were me, I'd disconnect each light and do and Insulation test across Line and Neutral, Line and Earth and Neutral and Earth. (make sure the switch is in the ON position whilst testing). If this proves to be OK, connect each light one at a time and energise the circuit and leave it on untill the 10 minutes have passed. This would find the problem. Ask your boss to invest in a tester ASAP to do a safe and proper job!!
