ryoko
Moved into a rental property in Sept with three storage heaters. They are Newlec ones (Image) with digital controls and were only turned on last month. Discovered yesterday when taking meter readings that rather then storing over night they had been asking as 'normal' heaters on the day rate as the boost mode was on auto. Turned boost off last night on one heater to see what happened and now heat at all this morning. There are two switches beside each heater that are both on. They are set quite low if that would effect it. Also my meter is what I was told by supplier is a complex meter with two tariffs, one just for the heaters, that one has lot chanced since that reading which is why I realised something was wrong. What am I doing wrong?
