Hi can anyone help, I have removed a rear door of my property which was fitted with a reed type electromagnet switch with an internal biscuit. Unfortunately this switch was accidently broken, which isn't a problem as I have no need for it however I have been advised that I should fit a replacement biscuit to the terminals in the key pad module. My problem is that the biscuit has three legs blue - yellow + and white anti tamper how should I fit this at the terminal strip as there is obviously only blue and white terminals. Any help would be appreciated.
regards,
mike..............
regards,
mike..............
