The only issue that I have with immersion from lightly loaded ring (providing its middle-ish on ring), is the 13A fuse spur, many makes seem poorly made and drawing 13A continuiusly leads to failure of fuse carrier. This also applies to when someone puts in dedicated immersion circuit and fits 13A fuse spur on end instead of 20A DP switch (why?).
Seen many panel and downflow heaters cause fuse in spur to become hot from poor contact, damaging the plastic of the fuse carrier, leading to the front of it comming away when you try and pull fuse leaving live fuse still in place!
