- Feb 5, 2009
- 5,612
- 0
The hot water is my flat comes from an Immersion Heater which is timed to come on twice a day so pretty old system but cant afford to upgrade boiler so have to make do with this.
Last night it packed up and on closer inspection after taking the lid off where the wires are terminated, the neutral was char grilled and had melted. The terminal had got so hot it had moved into the thermostat so gotta replace it today. Unfortunately the tank has to be un-plumbed and withdrawn from the cupboard then new element replaced then plumbed back in as the f&e tank is right above it and the element is quite long. (the flat is all on ground floor.. so no tank in loft).
Anybody got any ideas why the neutral wire had melted as it wasent a loose connection. Maybe airlocks in the cylinder causing early failure of the heater element???
Any pointers would be greatly appreciated
Matt
Matt
