- Nov 28, 2009
- 14,710
- 866
Indesit W161UK model LB2000C washing machine.
Fault. When you start a program, it locks the door, then does nothing else.
It is NOT flashing an error code.
I know the controller is working, because if you create a fault, say by unplugging the pressure switch, then it will start rotating the dial, and will flash out the error code 10.
So in my case, it's not flashing an error code, so it does not believe there is an error.
Instead, I think it's operating normally. I think the program is waiting for something before moving onto the next step, but I don't know what it is waiting for.
I have the service manual (next to useless) for an almost identical machine but it has been no help.
I have traced out part of the wiring of the machine which I have attached. This is most of the wiring loom, and at least a functional part of how it connects on the controller board.
I know from the test points I have identified that the microcontrolller is not commanding any outputs on, apart from the door lock. So it's not asking the motor to run, and it's not asking any of the fill valves to open.
The only thing I can think is that it's waiting for confirmation of the door being locked.
The door is locked with a solenoid, and when locked the one and only contact on the door lock outputs 240V to the controller board. That appears to be working fine.
As far as I can tell, this 230v "door locked" only feeds out to other devices. I can't see anywhere on the controller board where it is actually used, so I can't see how the microcontroller gets to know about the door being locked.
Any ideas pleas on how this should work, and what is making it wait, doing nothing indefinitely?
W161UK page 1.pdf
W161UK page 1.pdf
