hi everybody. i am new to the electrical world and have no idea about electrics.
i need to somehow get electricity from my main consumer unit in the house by running a wire out of the house wall leading into the backgarden. 15metres down the garden will be the log cabin, which ive bought a consumer unit with plug sockets on it.
what sort of wire would i need? how thick? armoured cable?
the details of the consumer unit are as follows:
The Consumer Unit UK1 is a unit that consists of a 2 piece VO rated Moulded Base and Cover with 2 x 25mm, 12 x 20mm Conduit Knockouts and 7 Knockouts for Twin and Earth Glands. The unit carries the CE mark and the front cover is hinged at the bottom and is secured by 2 inset fastening screws at the top. Items included within the unit are:
1 x 63 Amp QA15C, 30ma Earth Leakage Unit to IEC 61008 for people protection
1 x 16 Amp QA-1 (13) Circuit Breaker to IEC 60898 to protect the Socket Outlets.
1 x 6 Amp QA-1 (13) Circuit Breaker to IEC 60898 to protect the Bulkhead Light.
1 x QA Safety Blank.
1 x 12 Way Mini Rail Mounting Tray with spare space to accomodate another 6 x QA 13mm Circuit Breakers.
1 x PEN Neutral and Earth Bar
3 x 13 Amp Socket Outlets to BS 1363
3 x 16 Amp Switches to switch the Socket Outlets to SABS 163-1978.
1 x 60-Watt Bulkhead Light to BS 4533: Section 102.1:1990. (Lamp not included)
1 x 60 Watt BC Lamp Holder to BS 61184.
1 x 16 Amp Switch to switch the Bulkhead Light to SABS 163-1978.
Ready Board can be used as a Consumer Unit to BS EN 60439-3:1991 including Amendment 1
4 x Wall Fixing Plugs and Fixing Screws.
Fully protected by an R.C.D. (Residual current device that measures the electrical current on the outgoing live and return neutral conductors. If any current imbalance exceeds the set trip value it turns off the power supply.)
Approved to BS EN 60439-3
i am planning on using the electicity for a table saw, belt sander, electronic drumkit and other various tools. would the consumer unit described be ok for this????
any help would be much appreciated. thankyou
