Hi.
Ive just been to a customers house that has asked to have the gas and water bonding done as a previous electrician had said he couldn't sign it off as there was no bonding. I asked what he was signing off and the customer didnt really know.
It turns out he had had a new bathroom fitted by B&Q but no alterations were done to any of the electrics. However B&Q told the customer that the supplementary bonding would need doing under building regulation blahblahblah. The bathroom fitter (not an electrician) had put an earth across the hot and cold pipe behind the sink ONLY and called it done! Then a NAPIT registered electrician had come in and "tested" it supplying the customer with a minor works certificate commenting that there was no protective bonding to gas and water.
There were no readings or anything in the applicable boxes.
The customer was charged £117 for this!
Am I right in thinking this is a load of b***ocks and B&Q are pulling the wool over pentioners eyes?
Just to add, it was a 16th edition consumer unit so the lighting circuits weren't RCD protected so the supplementary bonding would only need doing if you were altering the lighting circuit right? (or just put that circuit on the RCD side)
Hope all that makes sense.
Whats you view? Thanks
