should that not be copper tube and Al rod?It isn't coated it is clad. A copper rod is inserted through an aluminium tube and extruded. The purpose to prevent corrosion to the aluminium.
Very easy. Scrape it with a scalpel, razor blade etc. If Ali it will still be silver colour. If tinned copper you will see the copper after scraping off the tin.Is there a quick way to tell the difference ?
