johnb2713
I cant comment on your battery charging, I have no experience of Solax inverters, I would assume like all the others you simply set a schedule - charge from 00:30 to 04:30 daily.We have been on Go now for just over a week. Mind getting frustrated with the Solax X1-Hybrid-G4-5.0 as well as the eddi.
Not every night do the batteries charge during off-peak, adjusted the setting without success. Now spotted elsewhere that Charge/Discahrge1 and 2 have to set the same, so will now try this tonight.
The eddi also does not retain the schedules each night to charge the immersion heater, even though I have set them for every day.
Pulling hair out time. Help required please.
EDDI again is a straight forward setup with one slight exception. With EDDI you set the start time and the duration (not the end time). So, 00:30 and 4:00 set it for every day and that should be it. I assume you're setting it from the APP, could you post a screenshot of your schedule?
