Lagging or leading ????
L Plate
May 22, 2009
250
Hello there,
I'm bit stuck on some of my revision ... I'm okay to work out the answers but bit confused how to find out if it is lagging or leading ..
1. The power factor of the circuit having an impedance of 2 ohms and a resistance of 1.2 ohms would be >>>>
my answer is correct 0.6 but i put lagging instead of leading >> is there any easy way to remember it ?
thank you for your help
lplate
Hello there, I'm bit stuck on some of my revision ... I'm okay to work out the answers but bit confused how to find out if it is lagging or leading ..
lplate
This might be a stab in the dark, but when I was doing that section, I used the term C.I.V.I.L to remember what is what
C.I.V.I.L= Capacitive - Current leads Voltage
C.I.V.I.L = Inductive - Voltage leads Current
If that does not help, I'll get my coat :^O
This might be a stab in the dark, but when I was doing that section, I used the term C.I.V.I.L to remember what is whatC.I.V.I.L= Capacitive - Current leads Voltage
That memory aid was used a lot when I was at college and it did help us at exam time :)
thank you for sharing this ...
have a nice evening
Just done my 203 today & got a distinction.
Got 1 question on capactive reactance & resistance.
Just done my 203 today & got a distinction.Got 1 question on capactive reactance & resistance.
well done mate,
have you done the 305 as well?
