lath plaster
gordy71
Jun 29, 2009
236
Hi i have read the previous threads but im just looking for an answer as to whether its ok to install downlighters in lath plaster ceilings. I know it will be a pain from an installation aspect but i want to know if its ok from a fire hazard point. I will be replacing the existing ones with fire rated and there are no signs of smouldering. Thanks
Hi i have read the previous threads but I'm just looking for an answer as to whether its ok to install downlighters in lath plaster ceilings. I know it will be a pain from an installation aspect but i want to know if its ok from a fire hazard point. I will be replacing the existing ones with fire rated and there are no signs of smouldering. Thanks
Right...
Now I read this that you imply fire-rated fitting will reduce the risk of the light setting fire to the lath & plaster? :eek:
( If I have got me pants on me head again I appologise.. ) :p
BUT..
1/ Fire rated fittings are to reduce the passage of smoke between living compartments.
2/ It is nothing to do with the light fitting setting fire to the surrounding building structure.
:C
Consider:-
Many down lights are fitted onto or into wardrobes, bathroom cabinets, kitchen wall units, mounted directed on/in wood or chipboard construction.
IF any fitting got so hot that it was likely to cause combustion of the immediate surrounding material then....
I guess it would be exceptionally dangerous!!!!
Think if the unsuspecting homeowner wanted to adjust the angle of an eyeball or do a bit of decorating near by and accidentally touch the fitting..
Whist may be a tad warm...
It wont be getting that hot..
Fire rated or NON fire rated..
You only need fire rated if you want to stop smoke from a fire in the room below getting through to a room above to rapidly!
If I have miss read you intentions then again sorry..
but that's how your question appears to me?
Lath & plaster...
Just need a good quality cutter...
and something to capture all the dust and carp that flies off!!
GuinnessGuinness
Right...Now I read this that you imply fire-rated fitting will reduce the risk of the light setting fire to the lath & plaster? :eek:
BUT..
:C
Consider:-
Lath & plaster...
GuinnessGuinness
Yes thanks for your replies guys, i do realise fire rated is to prevent the spread of fire, maintain the fire barrier and not less likely to cause one.
