LED's
M107
Billy-the-Kid
Feb 18, 2008
5,564
28
Berkshire
Afternoon boys & girls all well I hope :)
I have a little job on the go (first fix) wiring out a loft conversion, customer has now asked for 8x led's in the skeeling (zone1) above the bath...anybody got some recomendations for bathroom led's?
Just to make it a real pain in the **** got to get round the celotex insulation in the skeelings :(
Mr Sworld
Electrical Technician
Mar 21, 2008
1,152
We've been experimenting at work with lo-energy GU10 replacements.
1st thing is that most of them won't fit flush into exsisting downligh fittings. :(
We've tried:
1. Cold Cathode. Gives out a light that is almost 'moonlight', not recomended for bathrooms.
2. GU10 CFL's. The megaman ones are good but you don't get the 'tungsten' colour temperature.
3. Multi LED versions. A very white light but their output sucks!
4. Single LED. These are good, a very bright light but the angle of distribution can be quite narrow. Such as this.
However the single lamp LED's generate a lot of heat (as can be seen from the size of the heat sink on the above example) and I'm not sure how they would cope with being sealed into a Zone 1 or 2 bathroom fitting!
Osram are doing a 35W Decostar halogen that promises the equivalent output of a 50W version. They also do a 20W version too. See here.
Feb 27, 2008
11,034
Hello m107
I havn't had much to do with led's. I didn't think you would get the light output at present from them. I have used snaplite low voltage downlights on quite a few jobs in celotex ceilings with no probs. They do ip rated versions as well. Their website is www.snaplite.co.uk.
batty
Stoday
May 28, 2008
9
Interesting.
However, I note that the spec gives no indication of the lumen output. I wonder why not?
Mr Sworld
Mar 21, 2008
1,152
Interesting.However, I note that the spec gives no indication of the lumen output. I wonder why not?
I've not seen a low energy light that can match the lumen output of a 50W halogen yet. So it's a choice of low energy but with more fittings to give a comparable lumen output for less halogen fittings.
Horses for courses........
ABC Technical
May 1, 2008
885
Have you looked at OLED's yet, they are much better than a standard LED.
Mr Sworld
Mar 21, 2008
1,152
I haven't seen Organic LED's in fittings yet. Could you post a link?
