- Mar 19, 2008
- 528
- 65
O.k adaptable box with a large strip of nylon connectors in acceptable?imagine a more prof block connector situation kinda thing.!!!!!
you can loop from a sw if you want apache, nothing in this game is wrote in stone,Thanks steps. Does a new addition have to come from this central point or can you have a combination and loop from a switch?
its is indeed sir, do you think that would comply with BS7671.?O.k adaptable box with a large strip of nylon connectors in acceptable?
Yes more appropriate but would the other not comply(if you were stuck for more appropriate connectors on a sunday.its is indeed sir, do you think that would comply with BS7671.?although a large adaptable box fitted with a DIN rail and some appropriate connectors would be much more professional dont you think.?
Thanks that does sound sensible,can you buy the din rail setup off the shelf or is it a make your own up job?as central a point as is practical for each floor,I usually find beside CU for ground floor is fine,
and in the loft for 1st floor is good.
yes, usually a strip of 15a connectors within a suitable enclosure is fine, 5a conn seem too small to be suitable, but would be OK depending on your MCB/fuse size.
correct, thanks for pointing that out DD, although it was only an example of the type of enclosure to use. but well spotted, I suppose sometimes I dont think about pointing out things like this unwittingly when there could be some people reading this that wouldnt be as astute as I like to think I am, :^OAll,Just bare in mind with Step's solution, that all cables entering and leaving the enclosure (and the enclosure itself) need to be fix/clipped - otherwise it does not comply with the regs.
As the suggested enclosure has no cable restraints, the enclousre and cables need to be fixed to the same mounting (eg wall or backing plate - and not left loose in the loft).
D.
thats the job batty, good find.I have seen it done this way on a few jobs. Very popular on large houses in the past when cable was expensive although the price of it now it may come back into fashion. You could use an ashley purpose built one if you want to do it that way. I prefer to loop at switches as everthing is easily found. The problem with a central jb is if you didn't install it they can be a job to find with Mrs Jones clutter in her loft. Heres a link to an Ashley lighting jb. As DK says you would need to fit it on a board and then clip cables to it.http://www.allaboutelectrics.co.uk/doc/12/vid/2042/ASHLEY_JUNC_BOX___12W_CONN_STRIP.html
Batty
Ohh Dear i was just enjoying all those din rails and really like the ashley box, thanks steps and others.neutrals in switches every time i have come across it the job has been a mess 5 day wonder or 5 day wonder who took 3 days of spider method the job i am on at the minsupply from cu to box above board then split one to each switch l+n+cpc
unprofessional lost count of the times i have had to fix these type of job
if you have five end to one lighting circuit how to you test r1+r2 if i have offended anyone
with my rant then get a life then an apprenticeship
have a lovely sunday
well I for one am not offended, cos thats all that was, uninformed and ill judged, maybe I should have done one of those 5week apprenticeships you were on too.neutrals in switches every time i have come across it the job has been a mess 5 day wonder or 5 day wonder who took 3 days of spider method the job i am on at the minsupply from cu to box above board then split one to each switch l+n+cpc
Im chilled batty, thanks.Calm dowm Mr S, we all have our own ways of doing things, that is not to say any way is better than others. I usually wire into switches but as you say sometimes they can get a bit full especially with two way switching. There are many ways of complying with the red book.Batty
