Well i think everyone has covered this with as many points of view as possible...............The true use and point of this excellent forum continues.
Indeed so SSAB....
as with many areas of electrics...
there is NO right or WRONG way...
some have personal preferences others easy-on...
but as long as regs H&S, & EAWR satisfied...
then just pick your method appropriate to the circumstances
And the ability to discuss the options...
without slanging others off cuz you don't like their method..
is undoubtedly the benefit of this ere forum!!!Applaud SmileyApplaud Smiley
I would just add...
If I am wiring standard pendant roses... I still wire the traditional in-out rose.. loop to switch..
Whereas... if doing your typical wall lights... most definitely loop into either switch or a suitably located j/box with the lives & neutrals..
Cuz as and when someone wants to isolate and/or take down the wall lights..
tis nice and easy to disconnect the supplies to the wall..
OR if they want wall lights with integral switch, (e.g. miniature pull cord)
that they can turn on individually.. then need perm live NOT switched live.
so far more flexibly if all your ends are accessible somewhere to alter as & when required!
