matt.leung
both water and gas bonds go directly to the MET block, only the main earth goes from the CU to the MET,
the met can be in the cu and lots of other scenariosi said the main earth... it starts at the supply via the MET and into the CU.
The MET does not live inside the CU. MET (Main Earth Terminal). It is an external earth block.
I'm not misunderstanding any thing either. MET is where bonds go back to. No sharing main bonds and cpc's.Im not mistaking anything, you are misunderstanding
The earthing conductor of which there is only one connects to the met agreed.
The cpc then leaves the met and connects to the emt in the cu, which in turn connects all other cpcs agreed.
While we are at it lets make the cpc between the met and cu a combined cpc/main bonding conductor so effectively connecting the main bonding conductors to the met agreed?![]()
Regards chris
Clearly. That was our answer too.Im only disagreeing because i know im rightrayRegards chris
