matt.leung
w/e. i will be the first person to put my hands up if i am wrong....
why dont u draw us a pic to explain why u think u r right.....
X( :yellow card no on second thoughts Wet Fish headbang :red cardbad day explodebad day explode:innocent you forgot this :coat :^O :^Oif you think getting a 10m cable to a stop tap is hard, try getting 2 x 15mm pipes to a radiator in a fully tiled bathroom or kitchen or 6 pipes out of a cylinder cupboard and down a hall to each room .you sparkies dowt know the meaning of difficult lol.....
(awaiting abuse)........!!!!!
see below.![]()
10mm could be acceptable Noz, if Tails are less than 25mmA TNCS earth will usually go to a block with screws... sometimes it comes directly out of the head and then to the CU, if that is the case then I'd probably cut it so that there is only a few inches left and put that in an earth block and then take your 16mm earth from there!
Incorrecta1 sparkDon't forget though that if you put a new Earth connecting block before the CU then the Earth Block in the CU is no longer the MET...Correct and the new one becomes the MET Correct ....so all bonding needs to go back to that.
If you can not be bothered to comply with the regs that's one thing but to post saying that complying is wrong is just stupid. You have failed to comply with 542.4 if bonding does not go back to MET.Incorrecta1 spark
Ian. Bonding is going back to the MET via the Earth Marshalling Terminal in the C.U and via the combined cpc/Bonding conductor ,as already stated....I am bothered [as you eloquently put it],about complying with BS 7671 ,and the advice given does in fact do just that .............and furthermore is not ,as you put it, Stupid.. .Extract above is taken from The Electrical Safety Councils Essential Guide to The Wiring Regulations .If you can not be bothered to comply with the regs that's one thing but to post saying that complying is wrong is just stupid. You have failed to comply with 542.4 if bonding does not go back to MET.
