Been to have a look at a local call centre where the flourescent fittings are playing up. Place was totally refurbished 3 years ago. Around 100 recessed 4x18w T8 HF fittings with 2 ballasts per fitting. At a rough count I found 200 tubes unlit which would account for 25 percent of the entire installation. Almost all the failures are either 2 or 4 tubes which would indicate ballast failure.
What is puzzling me is why so many of these fittings are failing after only 3 years in service. The fittings are manufactured by Contrac Lighting (which is not far from me).
Anybody got any clue as to what is going on here as the manager is having kittens about the place gradually descending into darkness. I obviously don't want to start replacing the ballasts and then find some other issue is causing them to fail. But I can't think of what these issues (if any) could be. Am I missing something obvious?
