I am the friend whose consumer unit it is !The whole unit was installed new 2-year ago &, to the best of my knowledge, has remained undisturbed since that time. My tenant swears blind she never went near it. Nonetheless, it's puzzling what would suddenly cause this to happen.
Do you think it's wothwhile to get in touch with Crabtree themselves ? The whole place could have gone up in smoke after all ! Or, should I simply chalk it down to experience, swallow the cost of replacement & move on ?
Thanks.
IMHO it looks like a failure of the product, (most likely the push connection).
BUT....
the $100,000 question is..
Do you have a signed Electrical Certificate For the original install that would confirm that the product has been installed by a competent and qualified person?
An electrical certificate would have some test readings for the circuits such as Zs, which reads along the live (phase/line) conductors..
Through this push connection.
Good Zs readings would logically imply that when it was installed there was a good electrical connection at the now burnt out joint!
If NO certificate or readings are available... (although a bit of a long shot),.. It could be argued that the installing engineer/person/DIY didn't click push the switch fully home onto the bush bar? leaving a HR joint that has got progressively worse with time and use! :|
Was it installed by an electrician who was a member of one of the Electrical bodies? NIC / ECA / NAPIT / BSI / ELECSA ?
They may have tech support staff who may be able to offer a second opinion of the cause?
As long as you have Signed certs I would write a really stinky letter asking for explanations from Crabtree as to why their product has failed with possible horrendous consequences.
Considering they claim to have OUTSTANDING QUALITY? see here
http://www.electrium.co.uk/about_us.htm
And the quote from the above page:-
Crabtree, Wylex and Volex are renowned for their outstanding quality and excellent value for money. Specified worldwide, products are designed to satisfy the needs of specifiers, wholesalers, contractors and end-users in domestic, commercial and industrial markets alike, and are installed in many of the world
