gavindrummond
Ok thanks sidewiser
No, the sheathing MAY be purely for mechanical protection - it depends on the manufacturers spec.Right ok so can you correct me please If I'm wrong. Deep breath here goes lol double insulation is applied to appliances where cpc is not required? Insulation around a conductor is basic protection and the sheathing is purely for mechanical protection?
If you wish to start a new thread on these topics then please do, if posted in the students area perhaps more use could be made of the debates and instruction.gavin,That is the gist of it.
Please also see the IET CoP for In Service Inspection & Testing of Electrical Equipment.
There are several product standards that you will probably have less chance of access to, and this is covered in BS7671, part 412 to some extent.
If you wish to get more detailed info, perhaps again it would be good to start another thread, then others can add info to explain the details of Double, or Reinforced insulation of equipment?
Again, Mods?
Manotor surely you can see how his response has wound me up. I did not deserve this. Please don't ban me I have only just started to use the forum.
I will make two observations, Firstly, I have to disagree with your comment "I have only just started to use the forum" as you actually joined in Feb 2008. Almost at the start of the forum and you have posted in September 2008, see posts 20 & 21 here. http://www.talk.electricianforum.co.uk/electrical-inspection-testing-forum/1292-earth-loop-inpeadance.html So you have had a reasonable time to read the posts, even if not contributing much, to get the feel of how the forum operates. However, welcome back to the world of posting, the forum encourages healthy debate, especially as this industry is full of grey areas requiring interpretation. But is will not tolerate name calling, bad language and other such disrespectful posts.Thanks for the link Admin 3. It is clear to me now that the terminology of double insulated cannot be applied to 6181Y and that it is insulated and sheathed. . I stand corrected. But it is all a matter of terminology. Know ing that has not made any particular difference to how I install the stuff.![]()
He could of at least told us he had a trumpet..... :CHe does not go around "blowing his own trumpet" as it were, cos believe me, he has no need to....
