Thanks Phoenix for messing this up for me!If you take the tails through separate holes with stuffing glands in a ferious metal enclosure then our friend Mr. Current, first name eddy comes into play!![]()
You have to be very careful with having RCD's before the consumer unit even if they are time delayed if using single pole RCBO's in your main consumer unit. If you have a neutral to earth fault on a circuit it can take out the main RCD so you won't comply with discrimination reg. I say this through experience. To me it easier to just use an insulated enclosure on TT systems.The origin of an installation is the position at which electrical energy is delivered. So how can it be upsteam? In my mind I am imagining the main fuse is the origin. Therefore by introducing an RCD in the meter tails (after the meter) the tails entering the metal enclosure are protected fromearth faults by the RCD.
