Just looking at Reg ; 421.1.201 which says ............... Consumer units in domestic ( Household) premises have to be metal .
So , plastic ones can still be used in premises other than domestic (Household) . I assume . :C
Changing one in a solicitor's office shortly , which is a commercial premises ..I'm using plastic anyway but after 2016 it would still be plastic as its not a domestic household.
There are many premises which are not domestic (Household) Reg. states it quite clearly.
Also just thinking ...why the hell didn't they tackle the cause of the overheating , as in loose terminals by inadequatly trained operatives , consumer units do not burst into flames just because they are made of plastic .....they used to be made of wood FFS !!!! at one time .
Fires in consumers are caused by overloading & loose terminal screws ...oh and respected manufacturers having their products made cheaply by people who produce inferior goods by using cheapo materials & parts.
The fact that the case is made of plastic has no bearing on the matter whatsoever .
