Seen and done that, it makes it look a bit neater than sweeping over the top.
In that case, have the sounders been wired to 2 seperate circuits as described in BS5839 ? If not i will look up the reg number for you so you can get one over the lecturer, but remember that no one likes a smartarse :innocent2. Yes this is a working system (well I bloody hope it works haha)
Ah...in that case the fused spur is wrong [see Slips bit on isolation]The white thing is a skintop gland or stuffing gland and its just a fused spur
These were so rubbish to useNever seen a Mole crimper!
It was a stub seal to pot crimper AND a wedge inserter. Based upon a set of Mole Grips
I'll see if I can find a pic...
not sure I understand why was the MI in galv conduit?Just finished my first big pyro job
It was used on all the outside high level lighting and the lads who started the installation totally C***** it up, ran some cables down through the cavity to save time which have all failed and been replaced by myself there was also a few where they had rammed 2 2L1.5 pyros down a 25mm galv conduit to get down the wall and outside then bent them too tight to terminate them into U boxes snapping the outer at the pot and putting dead shorts on the cables :shakehead
All tested fine they claim but i cant see it, was good experince for me though its a great cable to work with and like its been said very satisfying to look back at a job well done and I also got myself a free set of pryo tools for the hassle and a lesson off an older spark on how to strip it with side cutter when your caught short so all good experince
