paul b b
Right Chaps,
I have assesed the job now and have some more questions (sorry!)
The house is TT, the meter box is on an outside wall, tails have a 30ma rcd in the meterbox, the tails then go up in to the bedroom where the cu is at floor level. No spare ways 16th split board.
the job will consist of:
redirect the current over head cable supplying the garage to underground, all circuits in place.
install power to barn aprox 125m away from house, install lights and a socket inside, 2x floodlights outside
install power to stable aprox 5m away from barn, install 3 lights and a socket inside 2x floodlights outside.
ok question time,
1) as the tails have a 30ma rcd then would i be better spliting before rcd and installing a cu with a s type?
2) is it ok for this cu to be inside a water tight box outside next to the meterbox?
3) can i run the swa from the barn into the stable without running 2 feeds?
4) what size cable would you install? 10mm2?
5) a small cu in barn and stable?
thanks chaps,
sorry for this, just want to get it right
thanks again
ok question time,
thanks chaps,
thanks again
