Hi Everyone
I would like to have your views and whether it is acceptbale to BS 7671.
A new plant has been constructed and there are about 10 motors of different ratings (3 phases 400V). The Contractor runs a copper bar all along with the galvanised cable tray and the copper bar is connected to the main earth bus bar. The copper bar is acting as a bonding for the cable tray and is interlinked at each motor metallic support frame.
The 3 phase motors power cable is a 3 core (Brown Black Grey) or 2 x 3 cores for star delta. The is no CPC connected in the motor connection box. Therefore, the motor support metallic structure which is bonded by the copper bar is also indirectly bonded to the motor frame (metallic to metallic). There are 6 Nos. motor support structure where 2 Nos. motors are mounted on each structure.
Is it acceptable as per BS7671?
Thanks in advance.
Thanks in advance.
