davidmichael
Active member
Good evening a query for UK someone kind enough to answer a DIY query.
I am refurbishing a flat and was asked by client to move a ceiling light to centre of ceiling as the lights in three bedrooms were positioned in non central positions.
As the ceiling has 5mm of plaster and then concrete I traced a line from the existing ceiling light junction box following the vertical and horizontal rule. So in essence the line was parallel to the wall. I used a machine to create the groove which is roughly 15mm deep and then fitted a 3 core 1mm wire cable to fix to the existing light junction box to new location on ceiling. Then cemented in the cable with quick set cement. It then occurred to me that this job may have to be done by a qualified sparky or signed off by one. I am also wondering if the cable needs to go inside a metal tube. Can someone help me clarify this please.
Thanks!
Thanks!
