Don't know how many guys on here use them on everyday working but if so, anyone got a decent brand to recommend that gives accurate readings? Seen a lot but priced a bit too cheap to believe their anymore than a volt/continuty tester. Thanks!
get yersel a neon then,Interesting the difference! Probably should have mentioned that 99% of my work is fault finding as its all repair based. Thanks but.
Please tell me how to test a DEAD circuit with a neon? :innocentget yersel a neon then,
will save you masses of time,
remember though, you shouldnt be doing it live,
Im loving step 6Canoeboy said:1. Prove NEON on Live Circuit first (This assumes you survive this step to proceed to step 2)
2. Isolate the supply (circuit)
3. Test the isolated circuit with the said NEON
4. If NEON doesn't light up then circuit is dead
5. Use wet finger to confirm the NEON was correct (IF NEON was bad and still alive proceed to step 6)
6. If you felt a Tingle or Got a BELT then go back to Step 1 and get a new NEON
6b. If still alive proceed to work on DEAD circuit
7. If circuit is not DEAD then you may be - See point 5
Errors and Omissions Accepted
Not for DIYers or Students
