hi
sorry about the delay been busy revising. I'm pleased to say I've passed my 17th edition.
Constructive criticism only please! :Blushing This has been tidied up now. It was a mess before with wires tangled into each other. btw the picture is taken at an angle. The cu isn't installed at an angle!
As Binky said..
Seen worse and seen better.....
Practical examples?????
Just be trawling though some old job photos to try and illustrate a bit....
First remember there are two distinct tasks related to CU's..
1/ getting it fitted and working in the first place....
2/ Doing inspection and testing at a later date...
If you are the person doing 2..
you will be well pi55ed off if the person doing 1 just slung everything in as quick as they could...
This was a CU I came across on a job I was doing some minor alterations on...
I did offer a price to tidy it all up..
but the customer didn't want it...
apparently it was installed by their uncle who now lives quite a distance away but he was an electrician!!!!!!???
B00dy nightmare to try and find the L-N&E of each circuit!!!!
Whereas this was a double CU stacked that I did a few years back...
Hopefully much easier to match the L @ MCB N @ N bar and E @ E bar....
Tips...
1/ Always form a short straight length on every conductor as it leaves the termination bar or MCB..
2/ Always add a short loop just after the straight bit on each conductor.
3/ ALWAYS follow rigorous numbering.. MCB 3 = N3 = E3, MCB 4 = N4 = E4..
Do not just terminate in the first free space!!!
4/ Wherever possible mount the CU on battens and utlise the rear entry points not the horizontal top/bottom surface knock-outs! It can make it easier to form cables tidy!
5/ Have a beer at the end of each days work Guinness
opcorn
