- Oct 22, 2010
- 14,621
- 1,171
Next door neighbour has had Solar PV installed...you should see it [but you wouldn't want to FFS!]
I have only seen the run from soffit to meter...that was enough.
25mm black Egatube down outside wall...5m drop held with 3 saddles.
Stop end box at bottom of run...fitted 'wrong way round'; that's to keep the weather out!
6mm t&e inside tube , through wall into an air-borne 40 x 25 trunk held to wall by gravity
t&e into new meter, then out of meter into his dist. board. don't know how/where it connects to board.
No sign of isolators anywhere; so if you want to isolate it you have to get ladder out and clamber into loft!
It was cracking the flags here at 5 o'clock tonight and he was getting 600w. They have told him to expect about 1kw between 12 and 2 in mid summer.
Trying to get a 'shufti' in the loft
I know marginally less than nothing about Solar PV but...
...mind you, scaffolding was a top job, done by local company
:coat
:coat
