Right Spark
- Nov 3, 2020
- 10
- -1
Hi guys first post here and looking for the best solution to this problem.
4 in a block flats with separate front doors.
External meter boxes for each flat.
The upstairs flats 25mm tails are run in a pipe box in the downstairs neighbours flat up into the upstairs flat and across the attic to their consumer unit.
Downstairs Neighbour has found the Upstairs neighbours tails In his property and has tapped into them (free electric, disconnected now).
I’ve been brought in to make sure this can’t happen again so my plan is to run a 25mm 3 core SWA externally then bring it into the upstairs property high level therefore bypassing the downstairs altogether and making it tamper proof.
My issue Is that I cant make up my mind of the best way to supply the SWA from the DNO’s 100a plastic isolator, which I obviously can’t connect into direct without an intermediary. It’s the usual sized electric/gas semi recessed external meter box containing the cable head, smart meter and isolator switch so there’s not a huge amount of room to add any more switchgear into.
My plan was to fit a separate meter box next to the original one, install a 100a SP+N Metal Switch Fuse ( https://www.cef.co.uk/catalogue/products/4390934-100a-sp-n-switch-fuse-with-100a-hrc-fuse ) and terminate the SWA into that with the DNO isolator feeding it. But I need to then figure out some way of getting the double insulated tales from the Isolator in the original meter box into my new one without it looking like a pigs ear, which I’m struggling to come up with a decent solution. Possibly copex?
In the property I plan to swap out the plastic consumer unit for an amendment 3 metal one and terminate straight into that.
Can anyone suggest anything better? As I say getting the supply into my new box via the isolator is the bit that’s puzzling me the most...
I’m open to any suggestions.
