Had a look at a newbuiuld in Hampshire area at the weekend, same place that had the sockets fitted at the wrong level to the worktop in the kitchen:slap
Anyway (& I'm not saying it's wrong but) why on a newbuild would you put 16mm T/E for the meter tails......... :shakehead
It is TT same as the 30+ year other properties in the road, so I recon when I next visit for a look round when the site is empty, there will be an RCD in the meter cab:tongue in cheek
http://i83.photobucket.com/albums/j293/gazjothomas/IMG-20120805-00084.jpg
Cant wait to get inside the place & find out where the cu is in relation to the tails through te wall
http://i83.photobucket.com/albums/j293/gazjothomas/IMG-20120805-00081.jpg
No sign of a rod yet either.........thats 6mm I'm assuming is going to the Gas & not a rod.
http://i83.photobucket.com/albums/j293/gazjothomas/IMG-20120805-00082.jpg
Why not plonk in 25mm swa or use another compliant method to get 25mm L/N & 10/16mm earth conductors in at first fix:C
The garage is the width of two paving slabs away from the side of the property just to the left of the meter cab & has no provision for electric in the garage............poor planning in my view......must drop my card through the door when the new owners move inROTFWL....9x properties needing power to garages ......niceB-)
