martinwinlow
I have a 400 litre thermal store (TS) with 2 immersion elements fitted one at 9kW and the other at 6. The plan was to use these to heat the TS up to 85 deg C or so on Eco7 electricity. The house is upside down and the TS is on the ground floor, sitting on 100mm of foam insulation and then on a concrete slab house foundation surrounded by bathrooms and bedrooms. Despite a good 100mm of spray-on foam insulation to the TS, concrete walls and what not, the immersion heaters are very noisy at night. I have reduced the output to 2 x 3kW temporarily but during the winter this is not enough heat to keep the UFH going during the night (even on set-back) and completely heat the TS ready for the next morning.
The immersion heaters are pretty basic ones and I have looked at trying to replace them with quieter ones. I gather there are 'low watts' ones with incalloy sheaths and so on. Question is, are they really much quieter?
Alternatively, bearing in mind the water in the TS is static, ie it is not circulated and therefore there is a limit to how much limescale can come out of it (it is also thoroughly doused with inhibitor) would an electric boiler of at least 15kW o/p be a guaranteed way of heating the TS quietly if the electric boiler is located next to the TS?
Thanks in advance.
Regards, Martin Winlow.
Thanks in advance.
