dougal
- May 13, 2008
- 178
- 0
Been called to look at an outside tap as the owner keeps getting shocks off it when her hands are wet.
tested the earth continuity via R2 tested OK.
tested ze that was OK
I put one of my test leads on the supply pipe and I get a reading of 4v ?:|
Tested between the tap pipe and another external copper pipe for continuity and all was OK.
the system is tncs that feeds two rewire able fuse boxes one for inside and one for an outbuilding.
What am i missing?
My current thoughts are to may be to replace the copper supply pipe with plastic to cure this problem.
what else could I do instead?
What am i missing?
