Oven cable
Dave SX
Nov 16, 2020
3
Hi. I have a new oven which uses 5.3kw and 30amp. The cable existing in kitchen is 8mm 32amp. Is this suitable?. Thanks
'think' isnt good enough. you need to know what size it really is before any proper advice can be given. there's also other factors to consider. chances are its good to go, but for all we know, your '8mm' or '10mm' is the the physical side of the cable and not its CSA, and it could be a bit 2.5mm²...
Ok thanks. I will look at direction when the oven arrives and get wire double checked. Many thanks Andy.
