Hi just needed sum advice on a periodic in spection report for a student accomodation. the flat has 16th edition board in so sockets are on rcd side and rest of circuits on main switch. i couldnt see and bonding in the bathrooms thou. but every thing else seems ok. what would i need 2 do for it topass the pir.i have been told it needs 17th edition db or the bonding doing is correct.
1/ An installation will NEVER pass or fail an inspection.....
It will be considered satisfactory or unsatisfactory.......
2/ The person doing the inspection will have sound knowledge and experience relevant to the nature of the installation being inspectied... AND the technical standards.!!!
Some may say that the phrase "I have been told".... and your question here..
could imply that you do NOT have "sound knowledge and experience relevent..."
as it could be argued it is rather a basic question.....
But I would never comment....
3/ All I will do is post a picture of some words from page 14 of GN3....
Anyone know what competence means???
:C
What were your resistance readings between the metal bits in the bathroom????
I presume you took some readings... as you couldn't see any bonding?
:coat
