BorisJ
You are wrong. Manufacturers instructions are for guidance only. Manufacturers instructions are often wrong so one should not follow them in that case.Not installing a DP switch for a shower is not following manufacturers installation instructions and I'm sure that that is against the regs ???
As an example if MI say you should fit an isolator they are wrong as it is not required by the regs.
Here is another incorrect MI asking for a 16 amp fuse in a fcu.
