You've not seen reverse polarity on a TNCS or PME system then,?Hi Steps, I agree with what you say 100% TT is obviously more reliable, unless the world falls off the end of your rod, AND, TT would be FAR preferable to relying on the DNO and their not too clever wiring... BUT for one thing... Look at the failure rates for RCD's.. MUCH MUCH more likely to have one of them fail, than a problem with the DNO supply.....
john...
Hi Steps, Yes i know i did, but in the context that the OP was referring to!!!!
john..
