Just bought new 12kw pool heater, need to know correct installation, suggested as follows:-
10mm t&e from non rcd side of 100a main fuse board running either in steel conduit or above ceiling in garage (3m), connect to 64a RCD fixed on inside of gable wall, 10mm t&e run through gable wall to outside junction box, connecting to 10mm armoured cable running to heater (3m).
Is this about right?.
